Cache for PDFViewThumb 6 years 9 months ago #14625
  • thiagopelikan
  • thiagopelikan's Avatar Topic Author
I'm trying to implement above as you mentioned but I'm having problems to do this.
I think the structure is ok but I didn't understood how to use BMP and DIB objects, could you please help me on that?
For now, I have:
protected void RenderThumb() {
        Bitmap bitmap = null;
        if (m_status == 2) return;
        if (m_page == null)
            m_page = m_doc.GetPage(m_pageno);
        File thumbPath = getThumbPath(m_pageno);
        if (thumbPath.exists()) {
            bitmap = CommonUtil.loadThumb(thumbPath);
            BMP bmp = new BMP();
            bmp.Create(bitmap);
            m_dib = new DIB();
            bmp.DrawToDIB(m_dib, m_dibw, m_dibh);
            Matrix mat = new Matrix(m_scale, -m_scale, 0, m_dibh);
            //How to get a Bitmap object and add to DIB Object
            //How to render a page using a DIB OBJECT
            m_page.RenderPrepare(m_dib);
            m_page.Render(m_dib, mat);
            mat.Destroy();
        } else {
            if (m_dib == null) {
                DIB dib = new DIB();
                dib.CreateOrResize(m_dibw, m_dibh);
                m_page.RenderPrepare(dib);
                m_dib = dib;
            } else m_page.RenderPrepare(m_dib);
            if (!m_page.RenderThumbToDIB(m_dib)) {
                bitmap = Bitmap.createBitmap(m_dibw, m_dibh, Bitmap.Config.ARGB_8888);
                //IS IT NECESSARY TO RENDER AS THUMB HERE?? I Tried m_dib.ToBMP without success
                m_page.RenderThumb(bitmap);
                CommonUtil.saveThumb(bitmap, thumbPath);
                mat.Destroy();
        if (m_status != 2)
            m_status = 1;
The files are saved correctly but loading it and render the page from the file is not working.
Tks,
Thiago
Cache for PDFViewThumb 6 years 9 months ago #14626
            bmp.Create(bitmap);
            m_dib = new DIB();
            mat.Destroy();
change to:
            m_dib = new DIB();
            m_dib.CreateOrResize(m_dibw, m_dibh);
            mat.Destroy();
            bitmap = Bitmap.CreateBitmap(m_dibw, m_dibh, ARGB_8888);
            bmp.Create(bitmap);
            m_dib.DrawToBMP(bitmap, m_dibw, m_dibh);
            bmp.Free(bitmap);
            bitmap.Compress(...);
Cache for PDFViewThumb 6 years 9 months ago #14627
  • thiagopelikan
The lines you ask me to change are responsible for loading bitmap from sdcard. Using your lines I'll never read files, isn't that correct?
Cache for PDFViewThumb 6 years 9 months ago #14628
sorry, not see your codes in correct way.
        if (thumbPath.exists()) {//if load from storage
            bmp.Create(bitmap);
            m_dib = new DIB();
            bmp.DrawToDIB(m_dib, 0, 0);
	    bmp.Free(bitmap);
        } else {//if not load from storage, we render to DIB, then draw to BMP
		if( m_dib == null )
			dib.CreateOrResize( m_dibw, m_dibh );
			m_dib = dib;
		if( m_status == 2 ) return;
		if(!m_page.RenderThumbToDIB(m_dib))
			mat.Destroy();
                bmp.Create(bitmap);
	        m_dib.DrawToBMP(bmp, 0, 0);
	        bmp.Free(bitmap);
        if (m_status != 2)
            m_status = 1;
