Cache for PDFViewThumb 6 years 10 months ago #14555
  • thiagopelikan
  • thiagopelikan's Avatar Topic Author
I need to use cache for PDFThumbView, I found that there is an property called save_thumb_in_cache at Global, but It seems that it is only implemented for PDFGridItem. Is there any sample on how to implement cache for PDFThumbView?
Tks,
Thiago Pelikan
Cache for PDFViewThumb 6 years 10 months ago #14556
the bitmap cache is generated at class PDFVCache, function "RenderThumb".
Cache for PDFViewThumb 6 years 10 months ago #14563
  • thiagopelikan
Inside PDFViewThumb there is a method vDraw and a line:
m_thread.start_render_thumb(vpage);
I think this is the line that calls the RenderThumb method for rendering the page. The problem is that everytime I scrolls to the right and then scroll back to the place I was, the cache goes null again. Check my attached image with log. Could you help me understand what is happening?
Cache for PDFViewThumb 6 years 10 months ago #14564
system ram(memory) has limit size. so, it is impossible to load all pages in memory. imaging a pdf file has 500 pages...
we only load pages that display on screen, and always unload pages off screen to free memory usage.
Cache for PDFViewThumb 6 years 10 months ago #14565
  • thiagopelikan
Sure, I undertand I agree with you that this is a good thing. My question is If there is somehow a way to save the rendered page as a file and only load the file instead of rendering it all again.
Tks
Cache for PDFViewThumb 6 years 10 months ago #14566
you shall make file name like "pdf_file_name_pageno.png".
in "render_thumb" method, you can create a Bitmap object, and then draw DIB to Bitmap object using m_dib.DrawToBMP().
at last save bitmap object to file.
at begin of "render_thumb" method, you shall check is "pdf_file_name_pageno.png" exists?
if exists, you can simply load from this file to Bitmap object, and create a DIB object, using BMP.DrawToDIB draw to DIB object instead of page rendering.
this will make lots file, so you may need delete all cache file when PDFView closed.
