extract math texts and equations from pdf 6 years 9 months ago #14622
  • zaraksis
  • zaraksis's Avatar Topic Author
hi guys, is there any way to copy and extract a mathematics text from a selectable document?
extract math texts and equations from pdf 6 years 9 months ago #14623
You can extract a page text using the following code: (check CommonUtil.getPageText())
String mPageText = null;
Page mPage = mDocument.GetPage(pageIndex);
mPage.ObjsStart();
mPageText = mPage.ObjsGetString(0, mPage.ObjsGetCharCount() - 1);
mPage.Close();
But there is no API to detect whether the text is a mathematical equation or not.
PDF doesn't specify a way to encode or represent maths inside documents so there's no way to detect maths formulas and even less to copy properly formatted text in a reliable way.
I suggest you look at the video at below link:
Last edit: by support. Reason: improved answer
extract math texts and equations from pdf 6 years 9 months ago #14624
  • zaraksis
thanks, how i can get the current page index?
extract math texts and equations from pdf 6 years 9 months ago #14629
You can use
ILayoutView.PDFGetCurrPage()
extract math texts and equations from pdf 6 years 9 months ago #14630
  • zaraksis
thanks nermeen, and how i can get total number of searched words?
extract math texts and equations from pdf 6 years 9 months ago #14631
