work with thumbnails 6 years 8 months ago #14685
You need to change PDFThumbView.OnPDFPageDisplayed
The following user(s) said Thank You: ShadMaxim
work with thumbnails 6 years 8 months ago #14688
  • luca.f
  • luca.f's Avatar
  • Thank you received: 10
Dear user,
the behaviour you're describing is handled by the methods vOnFling() and vOnMoveEnd() of PDFViewThumb.java
work with thumbnails 6 years 8 months ago #14692
Dear User,
We cannot reproduce this flicker behavior.
But the rendering is done in PDFViewThumb.vDraw
work with thumbnails 6 years 8 months ago #14705
Thanks for the feedback.
We will test it and integrate in the demo.
work with thumbnails 6 years 7 months ago #14751
The layout is measured in PDFViewThumb.vLayout, the default behavior is to calculate the scale factor based on the thumbnail max height and use the same scale factor for all pages.
You will need to calculate the landscape ones with different scale factor, and adjust the values passed to
m_pages[cur].SetRect(left, top, m_scale);
work with thumbnails 6 years 7 months ago #14779
  • luca.f
  • luca.f's Avatar
We aren't able to replicate the issue with our testing documents.
could you provide us the pdf file you're using?
