PDFViewAct.java OnPDFDoubleTapped(float x, float y) doesn't work right 6 years 8 months ago #14713
  • ericatudn
  • ericatudn's Avatar Topic Author
I am using Android version 3.52.6 sample project,
The method OnPDFDoubleTapped(float x, float y) of PDFViewAct.java dosen't work well, the zooming changed wrong.
Please help.
Thank you very much.
PDFViewAct.java OnPDFDoubleTapped(float x, float y) doesn't work right 6 years 8 months ago #14715
We have checked and the zoom is working correctly.
Can you be more specific please, what do you mean by changing wrong?
PDFViewAct.java OnPDFDoubleTapped(float x, float y) doesn't work right 6 years 8 months ago #14717
  • ericatudn
I think I know what's went wrong in my case, now.
It's because the screen was not refreshed after double tapped.
So I make it happen by add m_view.invalidate() as following:
public boolean OnPDFDoubleTapped(float x, float y)
float mCurZoomLevel = m_view.PDFGetZoom();
if (m_view.PDFGetScale() <= m_view.PDFGetMinScale())
Global.zoomStep = 1;
if ((mCurZoomLevel > Global.zoomLevel && Global.zoomStep > 0) ||
(mCurZoomLevel == 1 && Global.zoomStep < 0)) //reverse zoom step
Global.zoomStep *= -1;
m_view.PDFSetZoom((int) x, (int) y, m_view.PDFGetPos((int) x, (int) y), mCurZoomLevel + Global.zoomStep);
RadaeePluginCallback.getInstance().onDoubleTapped(m_view.PDFGetCurrPage(), x, y);
m_view.invalidate(); // Add this to refresh.
return true;
And now the zooming works fine.
So this is my explanation of my problem: "The screen was not refreshed after double tapped"
Dose this help you for understanding my case?
Do you have better solution then what I did (adding m_view.invalidate())?
English is not my native language and I have done my best, hope you can understand what I have tried to say.
Anyway, I solved this problem with my way, unless you have any opinion about this.
PDFViewAct.java OnPDFDoubleTapped(float x, float y) doesn't work right 6 years 8 months ago #14724
Thanks for the feedback.
We still cannot replicate it in the demo project, but glad that you found a solution.
