Native crash on Page#render - specific document & 3.53.4 Android SDK 6 years 2 months ago #15002
  • AnypadDev
  • AnypadDev's Avatar Topic Author
Hello, would like your help on a native crash when reading this specific document using the latest 3.53.4 version of the Android SDK. But we didn't encounter this crash when using 3.52.4 version of the Android SDK.
See the PDF file in app.box.com/s/phi8uo25udlwy0pnjs7zgsmzvfuixprv (5.43MB PDF file)
I'm not sure if this is caused by premature closure of the parent Document object, or if this is an issue with the library. Asking for your help to check the native stack trace
Thanks!
2020-04-22 10:28:21.329 17126-17398/com.sample.myapp A/libc: Fatal signal 6 (SIGABRT), code -6 (SI_TKILL) in tid 17398 (pool-26-thread-), pid 17126 (ple.myapp)
2020-04-22 10:28:21.368 17126-17370/com.sample.myapp D/com.sample.myapp.o.d: Done watching Thread-16
2020-04-22 10:28:21.415 17407-17407/? E/DEBUG: failed to readlink /proc/17398/fd/89: No such file or directory
2020-04-22 10:28:21.417 17407-17407/? E/DEBUG: failed to readlink /proc/17398/fd/149: No such file or directory
2020-04-22 10:28:21.439 741-741/? I/SurfaceFlinger: Display 0 HWC layers:
        type    |    handle    | flag |  format   |   source crop (l,t,r,b)    |         frame       | name
         Device | 0x7861284540 | 0000 | RGBA_8888 |   0.0    0.0 2560.0 1600.0 |    0    0 2560 1600 | com.sample.myapp/com.sample.myap[...]activity.MainActivity[17126]#0
         Device | 0x7861284930 | 0000 | RGBA_8888 |   0.0    0.0  190.0  138.0 | 1630  176 1820  314 | PopupWindow:f2ca3c1[17126]#0
         Device | 0x7861638fe0 | 0000 | RGBA_8888 |   0.0    0.0  200.0  239.0 | 2280  176 2480  415 | PopupWindow:59928c0[17126]#0
         Device | 0x7861284cb0 | 0000 | RGBA_8888 |   0.0    0.0  200.0   80.0 | 1817  176 2017  256 | PopupWindow:d04ff31[17126]#0
         Device | 0x7861639750 | 0000 | RGBA_8888 |   0.0    0.0  360.0  378.0 | 2184  176 2544  554 | PopupWindow:fd0fa33[17126]#0
         Device | 0x7861639bb0 | 0000 | RGBA_8888 |   0.0    0.0  130.0  109.0 | 2222  176 2352  285 | Pop
2020-04-22 10:28:21.439 741-741/? I/SurfaceFlinger: upWindow:63dcd25[17126]#0
         Device | 0x7861639de0 | 0000 | RGBA_8888 |   0.0    0.0  191.0  210.0 | 1936  176 2127  386 | PopupWindow:fbf3887[17126]#0
         Client | 0x7861639ad0 | 0000 | RGBA_8888 |   0.0    0.0  160.0   80.0 | 2065  176 2225  256 | PopupWindow:856f8d9[17126]#0
         Client | 0x7861284ee0 | 0000 | RGBA_8888 |   0.0    0.0  536.0   66.0 | 1012  767 1548  833 | PopupWindow:2c4e69b[17126]#0
         Client | 0x7861639130 | 0000 | RGBA_8888 |   0.0    0.0 2560.0   48.0 |    0    0 2560   48 | StatusBar[1839]#0
         Client | 0x786163a010 | 0000 | RGBA_8888 |   0.0    0.0 2560.0   96.0 |    0 1504 2560 1600 | NavigationBar[1839]#0
         Client | 0x786163a780 | 0000 | RGBA_8888 |   0.0    0.0   23.0 1600.0 |    0    0   23 1600 | ScreenDecorOverlay[1839]#0
         Client | 0x786163ac50 | 0000 | RGBA_8888 |   0.0    0.0   23.0 1600.0 | 2537    0 2560 1600 | ScreenDecorOverlayBottom[1839]#0
2020-04-22 10:28:21.485 17407-17407/? I/crash_dump64: obtaining output fd from tombstoned, type: kDebuggerdTombstone
2020-04-22 10:28:21.487 1007-1007/? I//system/bin/tombstoned: received crash request for pid 17398
2020-04-22 10:28:21.489 17407-17407/? I/crash_dump64: performing dump of process 17126 (target tid = 17398)
2020-04-22 10:28:21.500 17407-17407/? A/DEBUG: *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** ***
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG: Build fingerprint: 'samsung/gts4lvxx/gts4lv:9/PPR1.180610.011/T725XXU1ASG3:user/release-keys'
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG: Revision: '5'
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG: ABI: 'arm64'
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG: pid: 17126, tid: 17398, name: pool-26-thread-  >>> com.sample.myapp <<<
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG: signal 6 (SIGABRT), code -6 (SI_TKILL), fault addr --------
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG: Abort message: 'FORTIFY: strcat: prevented write past end of 0-byte buffer'
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x0  0000000000000000  x1  00000000000043f6  x2  0000000000000006  x3  0000000000000008
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x4  0000000000000000  x5  0000000000000000  x6  0000000000000000  x7  0000000000000018
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x8  0000000000000083  x9  c67ca812cb2d9092  x10 0000000000000000  x11 fffffffc7ffffbdf
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x12 0000000000000001  x13 000000005e9fabc5  x14 001377ffb5eedade  x15 00002a35de15102d
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x16 00000078bd19c298  x17 00000078bd0bd0fc  x18 0000000000000001  x19 00000000000042e6
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x20 00000000000043f6  x21 0000000000000020  x22 000000781cd5d803  x23 0000000000000000
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x24 0000007818afa3b0  x25 0000000000000000  x26 000000781640ec00  x27 0000000000000000
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     x28 0000007818af8060  x29 000000781c0dd730
2020-04-22 10:28:21.501 17407-17407/? A/DEBUG:     sp  000000781c0dd6f0  lr  00000078bd0af5cc  pc  00000078bd0af5f4
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG: backtrace:
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #00 pc 00000000000225f4  /system/lib64/libc.so (abort+116)
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #01 pc 000000000004d928  /system/lib64/libc.so (__fortify_fatal(char const*, ...)+120)
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #02 pc 000000000004e780  /system/lib64/libc.so (__strcat_chk+120)
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #03 pc 0000000000110278  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #04 pc 00000000001122f8  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #05 pc 00000000001282d4  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #06 pc 000000000011fc80  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #07 pc 000000000012723c  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #08 pc 000000000012ebb4  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #09 pc 000000000011e6cc  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #10 pc 0000000000127190  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #11 pc 0000000000163358  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #12 pc 00000000000fea20  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #13 pc 000000000005ec90  /data/app/com.sample.myapp-y_NNr2kdfY4VjpVMMCftIQ==/lib/arm64/librdpdf.so (Java_com_radaee_pdf_Page_render+452)
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #14 pc 0000000000561fe0  /system/lib64/libart.so (art_quick_generic_jni_trampoline+144)
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #15 pc 000000000055924c  /system/lib64/libart.so (art_quick_invoke_static_stub+604)
2020-04-22 10:28:21.679 17407-17407/? A/DEBUG:     #16 pc 00000000000d00e8  /system/lib64/libart.so (art::ArtMethod::Invoke(art::Thread*, unsigned int*, unsigned int, art::JValue*, char const*)+232)
Native crash on Page#render - specific document & 3.53.4 Android SDK 6 years 2 months ago #15003
found the problem.
the PDF file using a customer encoding information
the name is: "PDF-XChange-Viewer".
we will upload a new version later or tomorrow.
The following user(s) said Thank You: AnypadDev
Native crash on Page#render - specific document & 3.53.4 Android SDK 6 years 2 months ago #15005
  • AnypadDev
found the problem.
Thanks for the quick response. So is this a bug caused by the changes between 3.53.4 and 3.52.4 Android SDK? Are there any workarounds?
Native crash on Page#render - specific document & 3.53.4 Android SDK 6 years 2 months ago #15011
  • luca.f
  • luca.f's Avatar
  • Thank you received: 10
A new beta version has been published, it should include a fix for this issue.
Native crash on Page#render - specific document & 3.53.4 Android SDK 6 years 1 month ago #15047
  • AnypadDev
Hello, is there any timeline on when the next stable release is? One of our clients is pushing us for a schedule. It'd be great if you can advise on when the next stable release will be published?
