Set default PDF visualisation mode ( Android SDK ) 6 years 2 months ago #15018
  • robaba
  • robaba's Avatar Topic Author
how can i set default PDF visualisation mode from code ( horizontal/ vertical / single / dual page ) ?
Set default PDF visualisation mode ( Android SDK ) 6 years 2 months ago #15019
dear user:
it can changed in function:
com.radaee.pdf.Global.default_config()
"def_view" member of Global class.
Set default PDF visualisation mode ( Android SDK ) 6 years 2 months ago #15020
  • luca.f
  • luca.f's Avatar
  • Thank you received: 10
Dear user,
please check variable def_view inside Global.java. Set its default value in default_config() accordingly to your needs.
The following user(s) said Thank You: robaba
