RichMedia annotation not working 5 years 11 months ago #15082
  • MaxM
  • MaxM's Avatar Topic Author
Good afternoon, Radaee, I had a problem playing the sound annotation which is saved as page.AddAnnotRichMedia ("/ player / AudioPlayer.swf", newFile.getPath (), 1, document.NewImage (BitmapFactory. decodeResource (context.getResources (), R.drawable.ic_mic_white_circle_blue_), true), pt2); Everything works well if I transfer a PDF document between the clients of our application, but if the client wants to save it, for example, to a computer and open it using Adobe Acrobat Reader, Text and graphic are highlighted and read, then the sound does not work. .. Maybe for opening in another application I need to save additional information or fill in additional fields?
RichMedia annotation not working 5 years 11 months ago #15085
not understand, i tested AddRichMediaAnnot(), the annotation can play music in Acorbat.
the file is: www.radaeetz.com/123.pdf
i using following codes to add sound annotation:
			PDF_IMAGE dimg = m_doc.DocNewImageJPEG("f:\\img.jpg", false);
			RDRECTF rect;
			rect.left = 100;
			rect.top = 100;
			rect.right = 436;
			rect.bottom = 566;
			m_doc.Page_AddRichMediaAnnot(page->page, "E:\\workspace\\output\\AudioPlayer.swf", "F:\\Seaside.mp3", 1, dimg, rect);
			m_doc.DocSave(NULL);
The following user(s) said Thank You: mrsmrd
RichMedia annotation not working 5 years 11 months ago #15086
this path: "/player/AudioPlayer.swf", maybe a problem.
all file path shall be absolute path.
also newFile.getPath() may return relative path.
RichMedia annotation not working 5 years 11 months ago #15088
  • mrsmrd
  • mrsmrd's Avatar
I don’t know why but blocked my account from which I asked this question.
I'll try to change the path
RichMedia annotation not working 5 years 11 months ago #15089
the PDF file you attached, has not embed file "VideoPlayer.swf" to PDF file.
so, "/player/AudioPlayer.swf" is not exists.
next time, you can check file exists, before this method invoked.
RichMedia annotation not working 5 years 11 months ago #15090
  • mrsmrd
  • mrsmrd's Avatar
1. Tell me how you look that the file does not contain a player ("VideoPlayer.swf").
2. What needs to be done to play sound in www.radaeetz.com/123.pdf on windows 10, Adobe Reader is installed
