RichMedia annotation not working 6 years 1 month ago #15091
for normal richmedia annotation, GetRichMediaItemAsset(0) shall return "AudsioPlayer.swf".
otherwise, the player is not embed to PDF file.
The following user(s) said Thank You: mrsmrd
RichMedia annotation not working 6 years 1 month ago #15092
  • mrsmrd
  • mrsmrd's Avatar
I changed the way I saved the path to the player and the sound file, but I still can’t play it in Adobe Acrobat Reader.
Could you read my annotations at home?
Thank
RichMedia annotation not working 6 years 1 month ago #15093
  • mrsmrd
  • mrsmrd's Avatar
UBFV20200601-005121-SUP
RichMedia annotation not working 6 years 1 month ago #15094
sorry, what issue?
are you sure you player file is exists on storage? and the player file can be read on storage?
RichMedia annotation not working 6 years 1 month ago #15095
i have tested on Android as following codes:
		File fplayer = new File("/sdcard/AudioPlayer.swf");
		File fcontent = new File("/sdcard/Seaside.mp3");
		File fimage = new File("/sdcard/player.jpg");
		if(fplayer.canRead() && fcontent.canRead() && fimage.canRead()) {
			DocImage dimg1 = m_doc.NewImageJPEG("/sdcard/player.jpg");
			page.AddAnnotRichMedia("/sdcard/AudioPlayer.swf", "/sdcard/Seaside.mp3", 1, dimg1, new float[]{100, 200, 100 + 275, 200 + 50});
		else
			Toast.makeText(this, "invalid parameters", Toast.LENGTH_LONG).show();
and after invoked, the PDF file can play the music in Acrobat.
RichMedia annotation not working 6 years 1 month ago #15096
  • mrsmrd
  • mrsmrd's Avatar
Thanks for the answer, you were right. I checked everything and it really works with ordinary songs in mp3 format, but my problem is a little different ... The problem is that I use sound recording in android through a microphone ("MediaRecorder"), and I can’t play this sound recording in Adobe Acrobat Reader Maybe you have any advice or recommendations in this regard. Thank.
