Mgration of a project from Eclipse Kepler to Android Studio 5 years 10 months ago #15235
  • Morris
  • Morris's Avatar Topic Author
Hello there,
i want to migrate an old project from Eclipse Kepler to Android Studio which is using the pDFReader library.
Everything worked fine except one issue:
error: package com.radaee.view does not exist
Here´s the code that is causing this problem:
    public void OnAnnotClicked(com.radaee.view.PDFVPage vpage, Page.Annotation annot) {
Seems like the package PDFVPage doesn´t exist anymore.
I am glad for any help!
Morris
Mgration of a project from Eclipse Kepler to Android Studio 5 years 10 months ago #15236
you can copy implement codes of this function, and then delete whole this function.
the java shall report error, if this function is required for callback.
java can generate new function if this function is required, and then you can paste copied codes to new function.
Mgration of a project from Eclipse Kepler to Android Studio 5 years 10 months ago #15237
  • Morris
I don´t need this method so i don´t hava any code inside the method.
When i delete this method Android Studio/Java tells me to implement it again which leads to the same error again because my class implements the PDFReader.PDFReaderListener
public class EditPDF extends Activity implements PDFReader.PDFReaderListener, OnClickListener {
So this doesn´t help me. Sorry.
Mgration of a project from Eclipse Kepler to Android Studio 5 years 10 months ago #15238
so, please enter interface: PDFReader.PDFReaderListener
and then delete method OnAnnotClicked
Mgration of a project from Eclipse Kepler to Android Studio 5 years 10 months ago #15239
  • Morris
Thanks! I did so but i am getting a new error now:
error: cannot access PDFView
You can find the src folder of my pDFReader library in the attachments (no package named "view" in it):
File Attachment:
File Name: PDFReader.zip
File Size:70 KB
Is there any later version the library available maybe?
Last edit: by Morris. Reason: attachment added
Mgration of a project from Eclipse Kepler to Android Studio 5 years 10 months ago #15240
dear user:
may you try our last version of demo?
because, you are using very old java class that we have deprecated years ago.
and we won't support these old class ever.
the new demo using opengl to tiling pages, and support very large scale value.
you need to do shall be:
1. keep your app id,
2. save your key,
3. then restore the key in new project.
4. develop some new feature based on new project.
the new class shall cover all features of PDFView class.
