AndroidX project with ViewLib does not compile 5 years 8 months ago #15301
  • simone.p
  • simone.p's Avatar Topic Author
I have and Android project that uses AndroidX libraries.
I imported in my project your SDK module ("ViewLib") but it doesn't compile.
I think the problem is that your module works on "android support" and mine on "androidx", how can I make my project compile with both?
AndroidX project with ViewLib does not compile 5 years 8 months ago #15302
so, you have to convert viewLib to support AndroidX by following steps:
1. click menu:
2.select all references, and click "Do Refactor"
then finished AndroidX support.
AndroidX project with ViewLib does not compile 5 years 8 months ago #15303
  • luca.f
  • luca.f's Avatar
  • Thank you received: 10
Here's a KB page for more extensive info.
