OnPDFSelectEnd return text without white spaces 5 years 5 months ago #15405
dear user:
it is possible manage on java layer, if you can manage UTF-16.
that Page.ObjsGetString(0, objsCharCount) return whole string value of page, and index of each char in this string shall be in UTF16 order.
another method Page.ObjsGetCharRect() return rectangle of each char.
that mean, you can judge by own, using char rect and space between 2 chars.
but in this way, you shall manage UTF-16 code by yourself.
OnPDFSelectEnd return text without white spaces 4 years 10 months ago #15622
  • thiagopelikan
  • thiagopelikan's Avatar Topic Author
Could you give me an example how to do this?
For example, in the attached file, the ObjsGetString method gives me:
"TORCIDA T U M U L T U A AMBIENTE"
As I see, the 3 lines in the example are exactly with the same space between the chars
How can I use ObjsGetCharRect and extract the word from a RECT?
Tks,
Thiago
OnPDFSelectEnd return text without white spaces 4 years 10 months ago #15623
dear user,
i'm still not sure what you really want.
i share some codes here。
for example, you want get char code and rectangle area of a char by index:
String sval = page.ObjsGetString(start, end);
float[] rect = new float[4];
for( int i = start; i < end; i++)
   char code = sval.charAt(i - start);//encoding as UTF16.
   page.ObjsGetCharRect(i, rect);//array as [left,top,right,bottom].
   //todo: process each char.
OnPDFSelectEnd return text without white spaces 4 years 10 months ago #15624
Dear Thiago, your issue seems to be related to the way your test pdf file was generated and how chars are spaced on the page.
May you provide the file, please?
OnPDFSelectEnd return text without white spaces 4 years 10 months ago #15625
  • thiagopelikan
Hi, I had to upload the file to my repository because it has 6MB.
itgames-my.sharepoint.com/:b:/g/personal...zre9kwNyt5w?e=3dSTOv
Tks,
Thiago
OnPDFSelectEnd return text without white spaces 4 years 10 months ago #15626
Hi, we checked this PDF file, and tested in last version  of Edge(chrome core).
the extracted text is:
TORCIDA
T U M U LT U A
AMBIENTE
also, we tested in PDF XChange pro, it is same to Edge.
this is depends on blank judgement of PDF software.
