OnPDFSelectEnd return text without white spaces 5 years 6 months ago #15396
  • thiagopelikan
  • thiagopelikan's Avatar Topic Author
Hi, the method GetSelString() returns the selected text without any white spaces, is there any way to get the selected text with the white spaces?
Tks,
Thiago
OnPDFSelectEnd return text without white spaces 5 years 6 months ago #15397
It can be an issue tied to your specific PDF file.
May you provide one of your files, please?
OnPDFSelectEnd return text without white spaces 5 years 6 months ago #15398
  • thiagopelikan
Try to select some texts like "Investimento empurra PIB".
Tks,
Thiago
Last edit: by thiagopelikan.
OnPDFSelectEnd return text without white spaces 5 years 5 months ago #15402
  • thiagopelikan
Hello, were you able to open the file? If you succeeded please let me know so I could remove it from the attachment.
Tks,
Thiago
OnPDFSelectEnd return text without white spaces 5 years 5 months ago #15403
dear user:
we have checked your document.
and we found that Adobe Acrobat sometimes has no blanks too (between words).
the reason shall be: some text blank space is too short, space length shorter than blank judgement condition.
here is some example texts extract from Acrobat:
Ogoverno Jair Bolsonaro
(PSL) criou grupo de trabalho
comministros, desembargadoresejuízesparapropormaismudanças
nasleis trabalhistas.Além
deresolverpendênciasda
reforma da gestão Temer
—deefeitocontroversono
emprego,masquedesafogouaJustiça—,
ointuito é
apresentarnovaspropostas,
como o fimda unicidade
sindical. MercadoA23
OnPDFSelectEnd return text without white spaces 5 years 5 months ago #15404
  • thiagopelikan
Is there a way to make our behavior more like Acrobat?
If I managed to select some titles("Investimento empurra PIB") correctly, it would be great.
Tks for your support,
Thiago
