Problems with thumbnails 5 years 5 months ago #15423
  • MaxM
  • MaxM's Avatar Topic Author
Hello, Radae. There are problems with displaying thumbnails when first turned on. Problems appeared when using a very large pdf (184 MB). I attached a document to the Support Ticket UZZU20210212-005457-SUP. At the first load in your example, the vDraw (Canvas canvas) method in the PDFViewThumb class is triggered several times (7-8), on subsequent loads one by one. When I first load vDraw (Canvas canvas), it works hundreds of times (about 30 seconds), and this problem if at this moment, for example, turn the screen - everything freezes. Tell me what could be the problem or where to look for it. Searching for the error with the help of debug did not lead to anything. Thanks for the help.
Problems with thumbnails 5 years 5 months ago #15424
this because of scrolling. each scrolling position cause redraw.
consider that thumbnail view is small, each redraw shall be fast.
The following user(s) said Thank You: MaxM
Problems with thumbnails 5 years 4 months ago #15425
  • MaxM
Thanks for the answer. Is there any way to skip scrolling on first boot?
Problems with thumbnails 5 years 4 months ago #15426
dear user, please try to update 2 java files i attached here.
the new thumb view scroll and redraw only when viewer is visible.
we think this behaviour as minor issue.
