Added JPEG not appearing 5 years 2 weeks ago #15527
  • arlomedia
I can successfully import an existing PDF document into a new PDF that I'm building in memory, like this:
val combinedDocument = Document()
val stream = PDFMemStream(output)
combinedDocument.OpenStream(stream, null)
combinedDocument.SetCache(Global.tmp_path + "/ttt.dat")
val addDocument = Document()
addDocument.Open(documentFilename, null)
val context = combinedDocument.ImportStart(addDocument)
combinedDocument.ImportPage(context, thisPage, addPage + thisPage)
context.Destroy()
addDocument.Close()
combinedDocument.Save()
output = stream._data
Now I'm trying to add an existing JPEG file instead. From reading the source code and converting a few iOS examples, I've come up with this:
val addImage = combinedDocument.NewImageJPEG(documentFilename)
val combinedDocumentPage = combinedDocument.GetPage(addPage)
val imageResource = combinedDocumentPage.AddResImage(addImage)
val matrix = Matrix(1f, -1f, 0f, combinedDocument.GetPageHeight(addPage))
val pageContent = PageContent()
pageContent.GSSave()
pageContent.GSSetMatrix(matrix)
pageContent.DrawImage(imageResource)
pageContent.GSRestore()
combinedDocumentPage.AddContent(pageContent, true)
combinedDocumentPage.Close()
But the image doesn't appear. I tried a few different image files from different sources, and I think the image file is good because if I load it into a bitmap object, and click View Bitmap in the debugger, the image appears.
To test the rest of the code, I tried adding a line annotation, and that appeared:
val startPoint = FloatArray(2)
startPoint[0] = 50f
startPoint[1] = 50f
val endPoint = FloatArray(2)
endPoint[0] = 100f
endPoint[1] = 100f
combinedDocumentPage.AddAnnotLine(startPoint, endPoint, 0, 0, 10f, Color.RED, 0)
But an image annotation doesn't appear:
val frame = FloatArray(4)
frame[0] = 100f
frame[1] = 200f
frame[2] = 200f
frame[3] = 100f
combinedDocumentPage.AddAnnotBitmap(addImage, frame)
I found several forum posts saying "...then rerender the page," but I can't figure out how to do that. The only examples I've found work from a PDFView or PDFVPage, and I just have a Page object.
If the rerender is needed, how do I do that in this situation? Or am I missing something else?
I have a premium license.
Added JPEG not appearing 5 years 2 weeks ago #15528
dear user:
PDF system always process image object as (1 * 1) size.
so, when you need display an image to PDF file, you shall create Matrix like
Matrix mat = new Matrix(disp_width, disp_height, x0, top);
Matrix mat = new Matrix(disp_width, -disp_height, x0, page_height - bottom);
and then output image like:
pageContent.GSSave();
pageContent.GSSetMatrix(mat);
pageContent.DrawImage(imageResource);
pageContent.GSRestore();
Added JPEG not appearing 5 years 2 weeks ago #15529
  • arlomedia
Thanks for the quick reply. To use a simple Matrix example, should this work? It still shows no image:
[code]val combinedDocument = Document()
val matrix = Matrix(100f, 100f, 100f, 100f
[/code]
By the way, none of the objects created above show as null in the debugger. addImage, imageResource, combinedDocumentPage and pageContent all seem to be valid objects.
Added JPEG not appearing 5 years 2 weeks ago #15530
dear user:
what is "documentFilename"? is it absolute path to jpeg image file?
if you want add page as image from another PDF document, please render that PDF file to Bitmap object and save to jpeg file,
then add jpeg file to destination PDF file.
Added JPEG not appearing 5 years 2 weeks ago #15531
  • arlomedia
Yes, documentFilename is the absolute path to a JPEG file. I can load it with File() and display it in a WebView, so I know the path is correct and readable.
output is a ByteArray generated from an Android PdfDocument object. I'm building the PDF data in memory and then I want to add an image that's saved as a local JPEG file.
I don't want to add an image that's inside another PDF file. I only showed my code to import a PDF file to show which parts of my code are confirmed to work.
Added JPEG not appearing 5 years 2 weeks ago #15532
sorry, we have found the issue later.
your codes will cause Page.AddContent() return false.
because the content need invoke PageContent.Create() to initialize buffer.
so, whole codes shall be:
Document.DocImage dimg = m_doc.NewImageJPEG("/sdcard/img.jpg");
Page page = m_doc.GetPage(0);
page.ObjsStart();
ResImage rimg = page.AddResImage(dimg);
content.Create();
content.GSSave();
Matrix mat = new Matrix(100, -100, 100, 200);
content.GSSetMatrix(mat);
content.DrawImage(rimg);
content.GSRestore();
boolean bret = page.AddContent(content, true);
content.Destroy();
page.Close();
//m_doc.Save();
