Questions about SaveAs function 3 years 8 months ago #15774
  • Matthew
  • Matthew's Avatar Topic Author
RadaeePDF version :3.65.21
Test file: Test.pdf (38 MB)
Result: SaveAs-NG-Result.pdf (38.1 MB)
When we use doc.SaveAs to save the test file, we get wrong results. Please help us to fix this issue. Thanks.
But our test file exceeds the maximum attachment file size, can we email it to you?
Questions about SaveAs function 3 years 8 months ago #15775
You may open a support ticket from www.radaeepdf.com/support.
There you shall upload your file.
Questions about SaveAs function 3 years 8 months ago #15776
  • Matthew
Sorry, we are unable to open new support tickets.
When we click on New Support Ticket, we can't find anything.
Questions about SaveAs function 3 years 8 months ago #15777
May you try? It could have been a temporary issue.
During last few days we're experiencing some glitches on our google cloud environment.
Questions about SaveAs function 3 years 8 months ago #15778
  • Matthew
We create the support ticket. Please check it. Thanks.
Questions about SaveAs function 3 years 8 months ago #15781
  • Matthew
Dear sir,
Thanks for your support.
We can't post reply on support ticket. we don't know why.
When we try to implement libs.android.old.rar we get some errors.
No implementation found for boolean com.radaee.pdf.Global.activeStandard(android.content.ContextWrapper, java.lang.String, java.lang.String, java.lang.String) (tried Java_com_radaee_pdf_Global_activeStandard and Java_com_radaee_pdf_Global_activeStandard__Landroid_content_ContextWrapper_2Ljava_lang_String_2Ljava_lang_String_2Ljava_lang_String_2)
