Is possible to reduce pdf size using radaee ? 3 years 4 weeks ago #15802
  • Apparound
  • Apparound's Avatar Topic Author
Is it possible to compress a PDF and obtain a smaller file size using Radaee?
Is possible to reduce pdf size using radaee ? 3 years 3 weeks ago #15804
Yes, using the Master version of the sdk.
Is possible to reduce pdf size using radaee ? 3 years 3 weeks ago #15806
  • Apparound
Ok, I saw that in the master version , there's this method:
public boolean SaveAs(String path, byte[] opts, float img_dpi) {
return optimizeAs(hand_val, path, opts, img_dpi);
Is this the method to use for compressing the PDF, right ?To achieve the best quality/size ratio for the PDF, what settings do you recommend ?
