Android application crashes when scrolling PDF 2 years 10 months ago #15841
We're working hard on it.
We've many hundreds customers using the framework and your ticket is really surprising us.
We'll update you as soon as possible.
Android application crashes when scrolling PDF 2 years 10 months ago #15842
  • kaizhou
  • kaizhou's Avatar
  • Thank you received: 2
Dear user,
We may have found the root of your issue.
We have uploaded a file containing the potential fix, could you replace it and let us know if the issue is resolved?
regards,
RadaeePDF.com
Support team
Android application crashes when scrolling PDF 2 years 10 months ago #15843
  • bays
  • bays's Avatar Topic Author
Hello, thank you for quick response! We will check if it helps and I'll get back to you:)
Android application crashes when scrolling PDF 2 years 10 months ago #15844
  • bays
Hello guys! We will try your method, but there is one note, maybe you can respond.
You added a check:`if (pageno < 0 || pageno >= m_pages.length) return null;`but according to our developers it might be wrong since we can get NULL in that case and then crash with NPE (null pointer exception).
 Have you considered adding this check in `OnPageRendered()` method  (`PDFLayoutView` class) since `vGetPage()` can cause NPE in case of returning NULL?
Android application crashes when scrolling PDF 2 years 9 months ago #15852
  • bays
Hello guys,
It seems that the fix we used (in the post above) solved issue with PDF crashes. Thank you very much for your help!
Android application crashes when scrolling PDF 2 years 9 months ago #15853
  • bays
Hello guys,
