Native crash on Page#getOutlineDest - with 3.65.4 Android SDK 2 years 7 months ago #15859
  • AnypadDev
  • AnypadDev's Avatar Topic Author
Hello, I would like your help on a native crash using the latest 3.65.4 version of the Android SDK. Unfortunately, I have no idea how and why this crash happens, so I can only provide the following stack trace only.
I'm not sure if this is caused by unexpected outline data, or if this is an issue with the library, so it will be great if you can help checking the native stack trace.
Thanks!
Build fingerprint: 'samsung/xxxxxxxxxx/release-keys'
Revision: '0'
ABI: 'arm64'
Timestamp: 2023-12-11 10:54:12.308581686+0000
Process uptime: 71s
Cmdline: com.sample.myapp
pid: 24409, tid: 25379, name: pool-18-thread-  >>> com.sample.myapp <<<
uid: 10262
signal 11 (SIGSEGV), code 1 (SEGV_MAPERR), fault addr 0x0
Cause: null pointer dereference
5 total frames
backtrace:
  NOTE: Function names and BuildId information is missing for some frames due\n  NOTE: to unreadable libraries. For unwinds of apps, only shared libraries\n  NOTE: found under the lib/ directory are readable.\n  NOTE: On this device, run setenforce 0 to make the libraries readable.
      #00 pc 0000000000084fdc  /apex/com.android.runtime/lib64/bionic/libc.so (__strcmp_aarch64+28) (BuildId: f85c82661f93b28ab3119d33214bb7b9)
      #01 pc 00000000001f317c  /data/app/~~x_2ppdXMKdtT0VvsLPz35A==/com.sample.myapp-e7HoHhOz87UQkzIsuf8SIA==/split_config.arm64_v8a.apk!librdpdf.so (offset 0x3bf6000) (BuildId: e6bd805008876210ce95b903dc3093a55bdf7f2c)
      #02 pc 00000000001f53a0  /data/app/~~x_2ppdXMKdtT0VvsLPz35A==/com.sample.myapp-e7HoHhOz87UQkzIsuf8SIA==/split_config.arm64_v8a.apk!librdpdf.so (offset 0x3bf6000) (BuildId: e6bd805008876210ce95b903dc3093a55bdf7f2c)
      #03 pc 0000000000111a8c  /data/app/~~x_2ppdXMKdtT0VvsLPz35A==/com.sample.myapp-e7HoHhOz87UQkzIsuf8SIA==/split_config.arm64_v8a.apk!librdpdf.so (offset 0x3bf6000) (Java_com_radaee_pdf_Document_getOutlineDest+40) (BuildId: e6bd805008876210ce95b903dc3093a55bdf7f2c)
      #04 pc 0000000000093418  /data/app/~~x_2ppdXMKdtT0VvsLPz35A==/com.sample.myapp-e7HoHhOz87UQkzIsuf8SIA==/oat/arm64/base.odex (deleted)
