How to implement Bookmark? 13 years 6 months ago #1304
  • callsamik
  • callsamik's Avatar Topic Author
How to implement Bookmark using this SDK ?
How to implement Bookmark? 13 years 6 months ago #1306
bookmark in PDF file or out of PDF file?
using Document.getOutline to get outlines.
if you need bookmarks out of PDF, you can using class BMDatabase
How to implement Bookmark? 13 years 6 months ago #1322
  • callsamik
I'm trying to add bookmark to an opened PDF and after that also want to show a list of all bokkmarks.. Can you suggest how to proceed?
How to implement Bookmark? 13 years 6 months ago #1326
OK, it think you'd better record bookmark using SQLLite or XML?
How to implement Bookmark? 9 years 10 months ago #11105
  • mrawy
  • mrawy's Avatar
I implemented add outline like this:
public boolean addToBookmarks() {
        boolean success;
        float top = mDocument.GetPageHeight(0);
        Document.Outline outline = mDocument.GetOutlines();
        if (outline == null) {
            success = mDocument.NewRootOutline(String.valueOf(mCurrentPage), mCurrentPage, top);
            if (success) {
                pdfSave();
        success = outline != null && outline.AddChild(String.valueOf(mCurrentPage), mCurrentPage, top);
        if (success) {
            success = pdfSave();
        return success;
The problem is when i close the PDF after adding outlines and re-open it i can not get the outlines:
private void fetchOutlines() {
        if (mDocument == null) return;
        Document.Outline outline = mDocument.GetOutlines();//first root is always null
        fetchOutlines(outline);
    private void fetchOutlines(Document.Outline outline) {
        while (outline != null) {
            Toast.makeText(mActivity, "" + outline.GetDest(), Toast.LENGTH_SHORT).show();
            mOutlines.add(outline);
            Document.Outline child = outline.GetChild();
            if (child != null) {
                fetchOutlines(child);
            outline = outline.GetNext();
How to implement Bookmark? 9 years 10 months ago #11115
You need to make sure of the following:
  1. You have an activated premium license, to be able to change/add/remove the outline
  2. To re-open them make sure that the document is opened
Did you try this in the demo project or yours? and which version?
Note: i suggest you to create a new post as this one is very old.
