Could RadaeSDK help to improve my application? 10 years 3 months ago #10456
  • colliot
  • colliot's Avatar Topic Author
I'm currently working on an application, where i need to annotate (draw lines and text), add text(write text insertable in the document), make digital signature which i can insert in pdf files. I'm choosing between some idk in order to do that, could RadaeSDK can help me?
If yes where should i start in order to learn how to use it? following my demands, which pricing is the best for me?
Could RadaeSDK help to improve my application? 10 years 3 months ago #10457
It seems you will need a Premium license.
Look at sites.fastspring.com/gearit/product/rada...r=new&tags=radaeepdf to see actual prices.
The following user(s) said Thank You: colliot
Could RadaeSDK help to improve my application? 10 years 3 months ago #10458
  • colliot
Stay my second question: where should i look in order to learn how to code with RadaeSDK?
Could RadaeSDK help to improve my application? 10 years 3 months ago #10463
I suggest you to download the library from the download section : www.radaeepdf.com/download/download-android or www.radaeepdf.com/download/download-prev...4-radaeepdf-362beta2 and check the sdk functionalities
You can write on the forum and read the knowledge base articles here .
Maybe this will help you to start www.radaeepdf.com/support/knowledge-base...component&kbartid=41
