Supporting hyperlinks in PDF 9 years 10 months ago #11111
  • bNayal
  • bNayal's Avatar Topic Author
Hi ,
We are in process of evaluating your pdf rendering tool for our software.
I would like to know if your software also supports
1) Opening hyperlinks which are in the pdf.
2) These hyper links need to be opened outside your pdf viewing software.
3) So if the user is using your application in his mobile. He clicks the link in the pdf, then the default mobile browser should open and render the link in the default browser
Supporting hyperlinks in PDF 9 years 10 months ago #11113
yes this is supported, I suggest you to look at this to look at the supported features www.radaeepdf.com/ecommerce/technical-specification
You can check it in the RDPDFReader module, in the PDFViewAct class you will find the listeners, like OnPDFOpenURI, that handle that
Supporting hyperlinks in PDF 9 years 2 weeks ago #12591
  • funkyape
  • funkyape's Avatar
i know that this post is old, but how to use PDFViewAct on Universal Plattform?
I want to evaulate if it works like i wish and have only a trail license, is it included in trial?
can´t find PDFViewAct nor PDFLayoutListener
Supporting hyperlinks in PDF 9 years 2 weeks ago #12595
PDFViewAct and PDFLayoutListener exist in Android version.
You can test this feature using the demo project, it's already activated with a demo premium license.
If you want to test using your project, you need to give your project demo's package name/product id for the demo license to work.
If you still face problems, please write a post under the correct platform.
The following user(s) said Thank You: funkyape
Supporting hyperlinks in PDF 9 years 2 weeks ago #12597
  • funkyape
  • funkyape's Avatar
Thanks for reply.
yea, I found out yesterday that it was my wrong license... same code worked in the licensed demo application, I was only a bit confused because
I thought that the trial license have all features to test.
Haven´t found the information before :-)
