Using RadaeePDF SDK for the UWP 8 years 3 months ago #13648
Dear Alok,
To highlight a text you need to:
1-Activate the select tool, by clicking on the select tool button.
2-Start selecting the text on the page. (with the touch event)
3-As sson as the touch event finishes (touch up event), a popup will appear where you can choose the desired action.
4-Click the Ok button to confirm the action.
Note, The license needs to be activated, and the file needs to opened in write mode.
Check the attached screenshot.
Using RadaeePDF SDK for the UWP 8 years 3 months ago #13656
Dear Alok,
When the selection button is clicked, the selection is activated using
m_view.vSelStart();
in PDFReaderPage, then the touch event is handled in PDFView via:
OnSelTouchBegin
OnSelTouchMove
OnSelTouchEnd
and finally the listener OnPDFSelected in PDFReaderPage
So make sure that all these parts are present in your project.
Using RadaeePDF SDK for the UWP 8 years 3 months ago #13666
Dear Alok,
By doing a debug, can you check that all the states are handled correctly?
Is the method PDFVSel.DrawSel being called during the draw operation?
