PDF Contents not being rendered and ... 12 years 4 months ago #5614
  • fdelcaz
  • fdelcaz's Avatar Topic Author
I have a pdf which contents can be seen using adobe or whatever pdf reader but when I try to see it with radaee, contents aren´t being rendered, only the structure but not the fonts.
Also, checkboxes ticks are rendered as "4" instead of ticks
PDF Contents not being rendered and ... 12 years 4 months ago #5615
mostly, it happen when no font resources.
or language of texts are not supported for extern font.
The following user(s) said Thank You: dougskelly
PDF Contents not being rendered and ... 12 years 4 months ago #5617
  • fdelcaz
Thanks for your answer. The Font is Arial. How can I resolve it?
Last edit: by dougskelly.
PDF Contents not being rendered and ... 12 years 4 months ago #5618
you can send PDF file to:
This email address is being protected from spambots. You need JavaScript enabled to view it.
show links here.
PDF Contents not being rendered and ... 12 years 4 months ago #5619
  • fdelcaz
sent :)
PDF Contents not being rendered and ... 12 years 4 months ago #5621
confirmed, that has no problems.
