CJK fonts are garbled in Android6 9 years 10 months ago #10610
  • yimamura
  • yimamura's Avatar Topic Author
In Android6, the system font has been changed to NotoSans.
Therefore, we make the following modifications in order to take advantage of Japanese fonts.
Global.java
fontfileListAdd("/system/fonts/NotoSansJP-Regular.otf");
if( !setDefaultFont( "Japan1", "Noto Sans JP Regular", true )){ //Add
if(!setDefaultFont("Japan1", "DroidSansFallback", true) && face_name != null)
setDefaultFont(null, face_name, true);
if( !setDefaultFont( "Japan1", "Noto Sans JP Regular", false )){ //Add
if(!setDefaultFont("Japan1", "DroidSansFallback", false) && face_name != null)
setDefaultFont(null, face_name, false);
A result, Japanese font of NotoSans was displayed. However, it will not make sense character. Than there is a problem in CMap?
Tried in RDPDFReader that comes with the SDK.
I think that is happening, in all PDF that FONT is not embedded.
I think that it is the same state, Chinese, Japanese, Korean, CJK-Font at all.
CJK fonts are garbled in Android6 9 years 10 months ago #10611
May you provide one of you pdf file?
We will check it on some Android 6.0 devices.
From earlier check, it seems that font isn't from the official google repository www.google.com/get/noto/
Which device are you testing?
CJK fonts are garbled in Android6 9 years 10 months ago #10612
I confirm the NotoSansJP-Regular.otf, even if it's not signed by Google, is distributed on Nexus devices too.
Please, provide us on of your files.
CJK fonts are garbled in Android6 9 years 10 months ago #10614
attached a new version of Global.java with the edits regarding Noto Sans font.
We have checked it with some japanese pdfs and it works properly.
We are waiting for your pdf to continue the test.
Please check this new version and let us know if it's ok.
File Attachment:
File Name: Global.java
File Size:30 KB
The following user(s) said Thank You: yimamura
CJK fonts are garbled in Android6 9 years 10 months ago #10617
we have done some deeper tests, so we suggest you to don't use the Global.java I sent you before, because NotoSans font doesn't have all the charset for all the Oriental languages.
At the moment we have the best performaces with DroidSansFallback.
Today we will publish a new release candidate version of the library that first uses DroidSansFallback and then, if this is not present, uses NotoSans.
CJK fonts are garbled in Android6 9 years 10 months ago #10620
  • yimamura
Thank you.
I've tried Global.java shown, it is the same result.
Attach the PDF file and some of the capture.
RadaeePDFReader ver7.1.6 (GooglePlay)
Correct display - Japanese system font of Android4.x and 5.x
fontfileListAdd("/mnt/sdcard/Download/MTLmr3m.ttf");
github.com/android/platform_frameworks_b...ee/master/data/fonts
Are the three terminal was tried.
Samsung Galaxy S7 edge (Android 6.0.1)
HTC Nexus 9 (Android 6.0.1)
LG Nexus 5X (Android 6.0.1)
Last edit: by yimamura.
