Android PDF Viewer Display Issue 13 years 9 months ago #534
  • thekono
  • thekono's Avatar Topic Author
The Android PDF viewer is not properly displaying the following document (5 pages). If you use Acrobat reader or other viewer, you are seeing it properly displayed.
Stanley
Android PDF Viewer Display Issue 13 years 9 months ago #535
  • thekono
As the file size exceeded the limit. Here is the link to the file -
docs.google.com/open?id=0B9nboFXvPjaPWVM3WHlGYTI5RkU
Android PDF Viewer Display Issue 13 years 9 months ago #536
this file need CJK font as default font. so modify Global.init
and set default font to "DroidSansFallback".
this font may has some problems for some extern Latin characters.
the best way to support all characters is using fonts you owned.
Android PDF Viewer Display Issue 13 years 9 months ago #543
  • ysh19841211
  • ysh19841211's Avatar
I have already seen the following code in Global.Init
if( !setDefaultFont( "CNS1", "DroidSansFallback", true ) && face_name != null )
setDefaultFont( null, face_name, true );
if( !setDefaultFont( "CNS1", "DroidSansFallback", false ) && face_name != null )
setDefaultFont( null, face_name, false );
Can you tell me what to change?
Android PDF Viewer Display Issue 13 years 9 months ago #546
the problem is:
font in PDF using CJK characters.
but this font not defined for "CNS1" collection.
so you need modify:
if( !setDefaultFont( null, "DroidSansFallback", true ) && face_name != null )
if( !setDefaultFont( null, "DroidSansFallback", false ) && face_name != null )
Android PDF Viewer Display Issue 13 years 9 months ago #555
  • ysh19841211
I replaced the code you posted here into Global.init, but with no luck. Have any idea?
