Screen rotation seems to be glitched 8 years 11 months ago #12689
  • JQRL
  • JQRL's Avatar Topic Author
Hi, I've been using the screen rotation feature for the cordova plugin.
It seems that when i select and anotation and rotatw my screen, the view becomes glitched. I'm not sure if this is the case for everyone or just me.
Is thee a way to fix this?
Screen rotation seems to be glitched 8 years 11 months ago #12691
May you say on which platform are you working on? Android or iOS?
If Android, which kind of device, screen resolution/size, os version?
We'd do some internal tests on it.
The following user(s) said Thank You: JQRL
Screen rotation seems to be glitched 8 years 11 months ago #12693
  • JQRL
Screen rotation seems to be glitched 8 years 11 months ago #12697
Rotating while an annotation is selected will invalidate the saved annotation's position information.
The solution is to cancel the annotation selection, this can be done by adding the following method to PDFViewController:
public void onConfigChanged() {
	if(m_bar_status == BAR_ACT) {
		m_view.PDFCancelAnnot();
		m_bar_act.BarHide();
		m_bar_status = BAR_NONE;
And call it from PDFViewAct:
public void onConfigurationChanged(Configuration newConfig)
	m_controller.onConfigChanged();
        super.onConfigurationChanged(newConfig);
