xref issue 8 years 11 months ago #12799
  • Marat Faskhiev
  • Marat Faskhiev's Avatar Topic Author
1. There is no issue with opening original file by PDFSharp. Is it possible to not corrupt file after form filling?
2. I have the similar issue with another file. Original file: www.dropbox.com/s/t5jjnci2kz4xua7/REAL.pdf
xref issue 8 years 11 months ago #12800
This one is much better.
I've found only warnings but no errors in the PDF syntax.
May you provide also a filled document?
Are you filling the forms in interactive mode (the user is touching on fields) or programmatically?
If programmatically, may you send a sample of the code you're using?
I'll move all the updated information to the developers.
xref issue 8 years 11 months ago #12801
  • Marat Faskhiev
We are using interactive mode.
xref issue 8 years 11 months ago #12802
So, with our out of the box code?
I think I've much more information now and my colleagues should be able to work on a fix.
xref issue 8 years 11 months ago #12803
  • Marat Faskhiev
Yes. We just use cordova plugin. And we pass file to the server after it was filled by user.
xref issue 8 years 11 months ago #12804
  • Marat Faskhiev
Here is a link to the file after editing: www.dropbox.com/s/7xeesdbnwxablmc/Edited%20REAL.pdf
