xref issue 8 years 11 months ago #12789
  • Marat Faskhiev
  • Marat Faskhiev's Avatar Topic Author
We are using PDFSharp for PDF file editing at server side. We have an issue with PDF file which was edited by RadaeePDF Cordova plugin. When we are trying to open it by using PDFSharp we receive the following exception:
Unexpected token 'xref' in PDF stream. The file may be corrupted. If you think this is a bug in PDFsharp, please send us your PDF file.
It looks like RadaeePDF Cordova plugin corrupts file. The XREF table should contain a list to the objects of the PDF. In this case the XREF table includes a link to the XREF table.
Original file: www.dropbox.com/s/wyjtoqokthrrryb/Original%20File.pdf
Edited file: www.dropbox.com/s/3076hz16l19wcys/File.pdf
Last edit: by Marat Faskhiev.
xref issue 8 years 11 months ago #12790
There is something I'm not understanding.
The input file is a normal PDF while the output one is an pdf/a-1.
May you clarify the full flow?
Original -> compiled by radaee -> transformed to pdf/a-1 by pdfsharp?
There are some errors I can't recognize as generated by our side (for example the missing Zapf Dingbats font is a requirement from pdf/a-1 transformation).
May you send us the missing pdf file I guess you've in your full process?
xref issue 8 years 11 months ago #12791
  • Marat Faskhiev
File.pdf is not processed by PDFSharp. This file was created by RadaeePDF Cordova plugin for Android.
xref issue 8 years 11 months ago #12792
Ok, I'll double check with dev team.
xref issue 8 years 11 months ago #12793
  • Marat Faskhiev
Thank you.
xref issue 8 years 11 months ago #12798
It seems the original file has some corruption in the AcroForm structure.
I'm uploading the report generated by AcrobatPro XI.
Sorry if it is in italian.
It seems the original PDF generator (OpenOffice?) has some issue while generating forms.
File Attachment:
File Name: OriginalFi...orto.pdf
File Size:312 KB
