FAult Adress with renderToBmp 13 years 1 month ago #2948
you should ask "support" or This email address is being protected from spambots. You need JavaScript enabled to view it.
for this problem...
FAult Adress with renderToBmp 13 years 1 month ago #2950
  • jum
  • jum's Avatar
Unfortunately, i just got another pdf which crash.
I have open a support ticket for this issue (www.androidpdf.mobi/?option=com_j2mantis...ugid=RVI=&Itemid=560), and send you the pdf.
FAult Adress with renderToBmp 13 years 1 month ago #2952
FAult Adress with renderToBmp 13 years 1 month ago #2953
  • jum
  • jum's Avatar
ok fixed for now. Thanks
