FAult Adress with renderToBmp 13 years 6 months ago #1072
  • Chumper
  • Chumper's Avatar Topic Author
Yes, i downloaded the code and will integrate it.
I will report back here to let you know what happend.
FAult Adress with renderToBmp 13 years 6 months ago #1087
  • Chumper
I am also confirming the bug with your Gridimplementation.
However, i tried different implementation and the renderprocess crashed at the same PDF again and again.
After i deleted the File there was no Problem with your implementation. I will also test it with my implementation and report back with the PDFfile that caused the crash.
FAult Adress with renderToBmp 13 years 6 months ago #1091
  • Chumper
Status Quo:
Your custom Gridview implementation will crash
The Reader from Google Play Store will crash,
my own implementations crashes.
The following PDF causes the crashes, maybe you can take a look into it.
docs.google.com/open?id=0BxoIErG7un49WUNLX1VqQWJxajA
If you put this PDF in a folder and try to open the folder with the newest radaee Reader from the market it will crash, probably with the same error i mentioned in the first post.
Last edit: by d4ng3r.
FAult Adress with renderToBmp 13 years 6 months ago #1092
OK, fixed.
please wait for next version.
FAult Adress with renderToBmp 13 years 6 months ago #1093
now, you can test temporary version as:
www.radaee.com/files/PDFReader.rar
FAult Adress with renderToBmp 13 years 6 months ago #1095
  • Chumper
Yes, its working perfectly now.
Can you tell me what the problem was?
