Images are not displayed in pdf on x32 apk (zoom-in as a workaround) 2 years 10 months ago #15817
  • bays
  • bays's Avatar Topic Author
Hi there! We use RadaeePDF Master for Android 1.2.28 and faced next issue when in some cases images are not visible on x32. Zooming in solves the issue by the way (but it's still weird that I have to do that in order to see the images).Steps:take device with x32 system only (w/o support x64!)open test file drive.google.com/file/d/13_nrN1hbBs5u1GV...w?usp=drive_linklook at 2nd page.Screenshot is attached (Actual result vs expected result)
Last edit: by bays.
Images are not displayed in pdf on x32 apk (zoom-in as a workaround) 2 years 10 months ago #15830
  • kaizhou
  • kaizhou's Avatar
  • Thank you received: 2
Dear User,
We have made an update for our Master Android SDK, could you check it and see if that solves your issue?
regards,
RadaeePDF.com
Support Team
The following user(s) said Thank You: bays
Images are not displayed in pdf on x32 apk (zoom-in as a workaround) 2 years 10 months ago #15836
  • Max321
  • Max321's Avatar
Hello Radaee Support Team.
This issue is resolved with Master Android SDK 1.2.29.
Thank you.
