Bug/Problem with PRO license 13 years 1 month ago #2661
  • Asdonio
  • Asdonio's Avatar Topic Author
I bought the Pro license, I set the pro license and watermark goes away.
I'm using the pdfviewer2.8.3beta7
When i test your code in the sample project, dual page mode works fine.
When I use it in my app
PDFPos pos = m_view.vGetPos(0, 0);
pos is always null in the onSizeChanged method.
protected void onSizeChanged( int w, int h, int oldw, int oldh )
		super.onSizeChanged(w,h,oldw,oldh);
		if( m_view == null ) return;
		m_view.vResize(w, h);
		m_view.vSetScale(0, 0, 0);
		if( pos != null )
			if( m_goto_pageno >= 0 )
				m_view.vGotoPage(m_goto_pageno);
				m_goto_pageno = -1;
			else
				m_view.vSetPos(pos, 0, 0);
			m_view.vCenterPage(pos.pageno);
as you can see i'm using your code
is there a fix to the pos being always null?
Last edit: by prashant.meg.
Bug/Problem with PRO license 13 years 1 month ago #2663
oh, (0,0) seems out of page, it is in left margin side.
try:
www.radaee.com/files/PDFReader.rar
Bug/Problem with PRO license 13 years 1 month ago #2666
  • Asdonio
I can't understand the problem, i changed the values from (0,0) to many values and nothing works, pos is always null.
In your example it keeps working.
I'm out of ideas
Bug/Problem with PRO license 13 years 1 month ago #2673
do you think just using PDFReader class?
Bug/Problem with PRO license 13 years 1 month ago #2683
  • Asdonio
Yes I modified the PDFReaderAct and the PDFReader classes only.
Being able have the dual page to keep the right page and center it when I go to landscape is the only feature I'm missing in my project.
Bug/Problem with PRO license 13 years 1 month ago #2686
OK, it seems it's better to send me your demo peoject.
to: This email address is being protected from spambots. You need JavaScript enabled to view it.
i'll test it.
