Xamarin, Cordova and other third part
Activate license with Basic4Android
Basic4Android library
11 years 5 months ago
#8416
hsmobile
New Member
we used the B4A library in a project and now purchaced a lisence key. How do you "register" the library using the supplied key?
Regards,
Hawkstone Mobile Dev Team
Last edit: by
hsmobile
#8419
support
Administrator
Thank you received: 59
You should pur your activation key here: Source/Wrapper/RSPDFViewer/src/com/radaee/pdf/Global.java around lines 527.
We're writing a new knowledge base article about it.
10 years 10 months ago
#9550
Arya
New Member
Hello
did you write any article about it?
how can add license code to b4a app?
9 years 7 months ago
#11482
nermeen
Platinum Member
Thank you received: 87
You need to import the project, them modify
Global.Init
and call the correct activation method (
activePremium
activeProfessional
activeStandard
) with the license info..then recompile the jar
Compiling PDF forms
