Question about cordova plugin 9 years 8 months ago #11384
  • eastxing
  • eastxing's Avatar Topic Author
How to know the user has back from radaee pdf reader view and the file has been modified?
I add cordova plugin into a cordova app, I want to use it like this:
1. show a pdf files list to user;
2. user click one file then download it from server;
3. after file download, open it by radaee pdf reader;
4. user add some annotation and click back button, a dialog popup prompt user to save the modification;
5. user click "ok" button, save the pdf;
6. back to the first pdf files list view;
7. upload the modified pdf file to server;
I have implemented all steps except step 7, because I don't know when the user back from radaee pdf reader view and the file has been modified or not.
Thank you.
Question about cordova plugin 9 years 8 months ago #11385
Are you using the radaee pdf reader plugin within your Cordova application?
Is that's the case, we might introduce a new js command to retrive such an information.
I should ask you to be patient while waiting for our update.
Question about cordova plugin 9 years 8 months ago #11387
  • eastxing
Yes, I using radaee pdf reader plugin in my cordova app.
Looking forward to your update.
Thank you.
Question about cordova plugin 9 years 8 months ago #11410
We have updated our Cordova plugin ..
We have added a new js interface (getFileState) that can be used to get the state of the last opened file (not modified, modified but not saved, modified and saved)...
RadaeePDFPlugin.getFileState(
                               function(message) {
                                    console.log("Success: " + message);
                               function(err){
                                   console.log("Failure: " + err);
The plugin is now aligned with the latest Android version.
Question about cordova plugin 9 years 8 months ago #11430
  • eastxing
Thanks for your update.
But it is not my need. I still do not know when the user back from the PDF view to my app view (by pressed back button).
At last I implemented it myself by modify the cordova plugin source code.
To put it simply,
1. Modify file RadaeePDFPlugin.java;
comment:
intent.addFlags(Intent.FLAG_ACTIVITY_NEW_TASK);
change:
mContext.startActivity(intent);
to:
this.cordova.startActivityForResult((CordovaPlugin)this, intent, 0);
and add:
    public void onActivityResult(final int requestCode, final int resultCode, final Intent data) {
        if(requestCode == 0) {
            if(resultCode == cordova.getActivity().RESULT_OK) {
                Bundle extras = data.getExtras();// Get data sent by the Intent
                String information = extras.getString("fileState"); // data parameter will be send from the other activity.
                PluginResult resultado = new PluginResult(PluginResult.Status.OK, information);
                resultado.setKeepCallback(true);
                PUBLIC_CALLBACKS.sendPluginResult(resultado);
                return;
            else if(resultCode == cordova.getActivity().RESULT_CANCELED) {
                PluginResult resultado = new PluginResult(PluginResult.Status.OK, "canceled action, process this in javascript");
                return;
        // Handle other results if exists.
        super.onActivityResult(requestCode, resultCode, data);
2. Modify file PDFViewAct.java;
change function 'onBackPressed' to:
public void onBackPressed()
    if(m_controller == null || m_controller.OnBackPressed())
        if(m_modified) {
            TextView txtView = new TextView(this);
            txtView.setText("Document modified\r\nDo you want save it?");
            new AlertDialog.Builder(this).setTitle("Exiting").setView(
                    txtView).setPositiveButton("Yes", new DialogInterface.OnClickListener()
                       public void onClick(DialogInterface dialog, int which)
                            m_doc.Save();
                            Intent mIntent = new Intent();
                            mIntent.putExtra("fileState", "modifiedAndSaved");
                            PDFViewAct.this.setResult(RESULT_OK, mIntent);
                            PDFViewAct.super.onBackPressed();
                   }).setNegativeButton("No", new DialogInterface.OnClickListener()
                            mIntent.putExtra("fileState", "modifiedAndNotSaved");
                   }).show();
        else {
            mIntent.putExtra("fileState", "notModified");
Now when user back from PDF view, I can get file state and do my process.
Question about cordova plugin 9 years 8 months ago #11433
Thanks for the feedback,
But unfortunately, we cannot add such implementation in the standard version distribution; as it's oriented to apps specific needs and implementations.
