Xamarin, Cordova and other third part
Cordova and forms editing
3
4
5
6
9 years 5 months ago
#11858
Marat Faskhiev
Junior Member
Could you check cordova project? I just recreated it:
dl.dropboxusercontent.com/u/43914124/RadaeePDF-Cordova.zip
As I can see it contains latest version of the plugin. But I have the same issue.
#11859
nermeen
Platinum Member
Thank you received: 87
We've tested your project, and it's working correctly.
We have uploaded a
video
that shows our test using your project...
The following user(s) said Thank You:
Marat Faskhiev
#11873
Marat Faskhiev
Junior Member
Thank you.
I was able to run it successfully on different device. It works fine on Samsung SM-T320. Earlier I tested by using Sony D5503.
#11887
Marat Faskhiev
Junior Member
I'm experiencing another issue. When I'm trying to install this plugin to our application I'm receiving the following compile error:
com.android.dex.DexException: Multiple dex files define Ljavax/annotation/CheckForNull
It looks like some conflict with another plugin. Could you point me what I can do with this?
#11890
nermeen
Platinum Member
May be it's related to android-support-v4.jar, do you already have it as dependency? if yes, then you should remove one of them.
For Sony issue, we couldn't reproduce the issue on the simulator.
Marat Faskhiev
#11904
Marat Faskhiev
Junior Member
There was a conflict with crosswalk plugin. After I updated it issue was resolved.
3
4
5
6
How to show pdfnav.xml(PDFNavAct) file in my app ?
