Cordova and forms editing 9 years 5 months ago #11847
There was a problem with the form edit view, please update the cordova plugin and try again
The following user(s) said Thank You: Marat Faskhiev
Cordova and forms editing 9 years 5 months ago #11853
  • Marat Faskhiev
  • Marat Faskhiev's Avatar Topic Author
I updated plugin but still have the same issue.
Cordova and forms editing 9 years 5 months ago #11854
As seen in the screenshot, the from fields should be editable in their position.
The note dialog, is for stiky-notes annotations (not form fields)
Cordova and forms editing 9 years 5 months ago #11855
  • Marat Faskhiev
Here is screenshot from the last version. I just made it:
dl.dropboxusercontent.com/u/43914124/Scr...7-02-09-17-13-35.png
When I'm touching form field there is no keybord for editing value. Combobox fields are also unresponsive.
Last edit: by Marat Faskhiev.
Cordova and forms editing 9 years 5 months ago #11856
  • Marat Faskhiev
I'm testing by using Android 5.1.1.
Cordova and forms editing 9 years 5 months ago #11857
We have tested also on 5.1, no problem.
It seems like the plugin is not updated correctly, try to recreate the cordova project
