Using annotations with Cordova plugin 9 years 4 months ago #11994
  • davosp
  • davosp's Avatar Topic Author
I've been trying to use annotations and other features with cordova plugin vuit i get an alert that says: "This document is readonly" when i try to use annotations
This is my controller:
var app = {
    initialize: function() {
        document.addEventListener('deviceready', this.onDeviceReady, false);
    onDeviceReady: function() {
        var parentElement = document.getElementById('deviceready');
        var listeningElement = parentElement.querySelector('.listening');
        var receivedElement = parentElement.querySelector('.received');
        listeningElement.setAttribute('style', 'display:none;');
        receivedElement.setAttribute('style', 'display:block;');
        document.getElementById('loadpdf').addEventListener(
            'click',
            function(e) {
                RadaeePDFPlugin.openFromAssets({
                    url: 'www/A1. Manual.pdf',
                    password: ''
                }, function(message) {
                    console.log('Success: ' + message);
                }, function(err) {
                    console.log('Failure: ' + err);
        if (device.platform === 'Android')
            xhr = new XMLHttpRequest();
            xhr.open('GET', './A1. Manual.pdf', true);
            xhr.responseType = 'blob';
            xhr.onload = function() {
                var blob;
                if (this.status === 200) {
                    blob = new Blob([this.response], { type: 'application/pdf'});
                    window.resolveLocalFileSystemURL(cordova.file.externalDataDirectory, function(dir) {
                        dir.getFile('A1. Manual.pdf', { create: true, exclusive: false }, function(file) {
                            file.createWriter(function(fileWriter) {
                                fileWriter.onwriteend = function() {
                                    console.log('Successful file write: ' + file.toURL());
                                fileWriter.onerror = function(e) {
                                    console.log('Failed file write: ' + e.toString());
                                fileWriter.write(blob);
                } else {
                    console.log('problem: ' + this.status);
            xhr.send();
        } else {
            // iOS
            RadaeePDFPlugin.activateLicense({
                licenseType: 2,
                company: "Radaee",
                email: "radaee_com@yahoo.cn",
                key: "89WG9I-HCL62K-H3CRUZ-WAJQ9H-FADG6Z-XEBCAO"
                console.log('Activated license');
                console.log('License Activation failed');
app.initialize();
Using annotations with Cordova plugin 9 years 4 months ago #11999
You are using openFromAssets, and files opened from Assets cannot be modified.
You need to copy your file to the device, and use open instead:
RadaeePDFPlugin.open(
        url: "", //The path of the pdf to open, ex: "file:///mnt/sdcard/Download/Test.pdf"
        password: "" //password if needed
    function(message) {
         console.log("Success: " + message);
    function(err){
        console.log("Failure: " + err);
Using annotations with Cordova plugin 9 years 4 months ago #12010
  • davosp
I tried to build for my iPhone but i can't because the bundle id must be com.radaee.pdf.PDFViewer and it doesn't let me build the app for devices, so i just can test the app on iOS simulator. Is there any way to test on my iPhone?
Using annotations with Cordova plugin 9 years 4 months ago #12016
Have you set your team in General tab of Xcode project settings?
