Encryption 9 years 4 months ago #12087
  • calvintse123
  • calvintse123's Avatar Topic Author
I am currently using the demo and was wondering whether it is possible to encrypt a pdf using the cordova plugin. If so, can you explain how this would be done? Thanks!
Encryption 9 years 4 months ago #12088
Are you meaning open an unencrypted file and save it as encrypted?
That feature isn't available yet,
Otherwise, if you're looking for open an encrypted file, annotate it, re-save as encrypted again, yes... that's the out of the box feature.
May you confirm if you're looking for the first or second behavior?
Encryption 9 years 4 months ago #12098
  • calvintse123
Thanks for the reply. I would like to open an unencrypted file and save it as encrypted.
Encryption 9 years 4 months ago #12102
The team will include a new method to re-save the document as encrypted.
Note: you would activate a Premium license.
The following user(s) said Thank You: calvintse123
