Bookmarking 9 years 4 months ago #12129
  • calvintse123
  • calvintse123's Avatar Topic Author
I am currently testing the demo version of the cordova plugin and was wondering if I can bookmark sections of a PDF.
If so, how is it possible. Thanks
Bookmarking 9 years 4 months ago #12140
what do you mean with "sections" of a PDF?
In iOS version you can bookmark a single page and retrive it in the bookmark list
Bookmarking 9 years 4 months ago #12143
  • calvintse123
Is it possible to have that feature (bookmark a single page and retrieve it in the bookmark list ) on Android?
Bookmarking 9 years 4 months ago #12152
We have evaluated your request, and we will add a bookmark button (to add/remove page from bookmarks), and an API to get the bookmark list.
But unfortunately this wont be ready before 2 weeks.
So if you are in a hurry, you can implement it your self by changing the plugin source code (you can make use of com.radaee.pdf.BMDatabase, this post may help)
The following user(s) said Thank You: calvintse123
Bookmarking 9 years 1 month ago #12505
  • JQRL
  • JQRL's Avatar
Hi, has this been updated yet? I was directed here by the readme docs written by OP.
If not, is there a manual on how to use the plugin
Bookmarking 9 years 1 month ago #12507
Not yet, but it will be available by next Tuesday/Thursday.
To use the plugin you can check:
The following user(s) said Thank You: JQRL
