Extract text 9 years 3 months ago #12217
We have tested your document with the below code, and we were able to extract the text on all pages.
So how you are calling your code? Can you send us a sample project that can be used to replicate the issue?
Global.Init(cordova.getActivity().getApplicationContext());
Document m_doc = new Document();
if(m_doc.Open("/mnt/sdcard/Download/LE_9_text_extract.pdf", "") == 0) {
    for (int i = 0; i < m_doc.GetPageCount(); i++) {
            Page page = m_doc.GetPage(i);
            page.ObjsStart();
            String text = page.ObjsGetString(0, page.ObjsGetCharCount() - 1);
             Log.e("SJHY", "Text:" + text);
             page.Close();
 m_doc.Close();
Extract text 9 years 3 months ago #12219
  • miguel.garcia
  • miguel.garcia's Avatar Topic Author
Hi I have copied the same code but changin the document Path and ObjsGetCharCount always return 0.
This is my current code that has been added in RadaeePDFPlugin java class:
String path2OpenFile = "/mnt/sdcard/Android/data/com.efl.sjhy/files/LE_9_Analisis_NL_Seg_Vial/LE_9_Analisis_NL_Seg_Vial_1_20130205.pdf";
if(m_doc.Open(path2OpenFile, "") == 0) {
page.ObjsStart();
page.Close();
m_doc.Close();
So, is there any problem with the path?
m_doc.OpenFile returns 0 which means the document has been right opened.
Extract text 9 years 3 months ago #12225
Does Global.Init return true? (i.e. are you activating the license correctly?)
As if the license is not activated, the text cannot be extracted.
Extract text 9 years 3 months ago #12230
  • miguel.garcia
It returns false.
I am using the standard license that comes by default with the plugin.
Do i need to purchase another license for this feature?
Should i use our license (premium) for testing?
Extract text 9 years 3 months ago #12231
If you already have a license you can use it, if you want to use the demo license, you can call RadaeePDFPlugin.activateLicense following this article and make sure that the package name/product id is com.radaee.reader
The following user(s) said Thank You: miguel.garcia
Extract text 9 years 3 months ago #12232
  • miguel.garcia
Yes you were right i was trying to test our app with test account and as per the article the package name should be com.radaee.reader
After testing with this value i am able to get the whole pdf file text.
Thanks a lot
