Extract text 9 years 3 months ago #12203
  • miguel.garcia
  • miguel.garcia's Avatar Topic Author
Good morning.
We are working with your Cordova plugin and we are changing it to get text from every page, therefore we are changing the cordova plugin and interface and everything works as expected but getting the text.
We are using the premium license provided by the plugin it self and we are able to open the doc and every page after calling to objStart() method on every page we always get null when we call to ObjGetString method.
Checking out other posts we have added a delay to the process getting the very same results.
Here you have the example code:
int resOpen = openPDFDoc(path2OpenFile, "");
if (resOpen == 0) {
int numPages = m_doc.GetPageCount();
Log.e("SJHY", "numPages:" + numPages);
for (int i = 0; i < m_doc.GetPageCount()-1; i++) {
final Page currentPage = m_doc.GetPage(i);
currentPage.ObjsStart();
final Handler handler = new Handler();
handler.postDelayed(new Runnable() {
public void run() {
String text = currentPage.ObjsGetString(0,200);
Log.e("SJHY", "Text:" + text);
}, 15000);
Any idea?
Thanks a lot for your support
Extract text 9 years 3 months ago #12205
We have checked and the following code is working, are you facing this problem with certain documents?
if yes, can you send us a sample?
for (int i = 0 ; i < m_doc.GetPageCount() ; i++)  {
	Page page = m_doc.GetPage(i);
	page.ObjsStart();
	String text = page.ObjsGetString(0, page.ObjsGetCharCount() - 1);
Extract text 9 years 3 months ago #12206
  • miguel.garcia
I am trying to upload a file example but it exceeds the file allowed by the adminstrator.
Is there another way to send you the file?
Last edit: by miguel.garcia.
Extract text 9 years 3 months ago #12213
We have increased the limit, you can retry and if you still cannot upload, you can use dropbox, wetransfer or any file sharing software.
Extract text 9 years 3 months ago #12214
  • miguel.garcia
Lets check whether it can be uploaded
Extract text 9 years 3 months ago #12215
  • miguel.garcia
It seems it still exceeds the limit.
Would you mind trying to download from this url?
drive.google.com/open?id=0B-xf7TKFtDAvaTVKUGJobVBZZFE
