Xamarin android - missing binding for PDFReader 9 years 2 months ago #12433
  • petcha
  • petcha's Avatar Topic Author
I'm trying to implement the PDFReader in a xamarin android project.
However I cannot find a reference to the PDFReader class anywhere in the lib.
Does the C# binding to the PDFReader in the java lib still need to implemented?
Or is there another way of achieving the same?
Thank you
Xamarin android - missing binding for PDFReader 9 years 2 months ago #12435
PDFReader is deprecated since version 3.9 (has limits for performance and memory usage), we recommend to use PDFLayout instead.
For a guide, you can check:
Xamarin android - missing binding for PDFReader 9 years 2 months ago #12437
  • petcha
Thank you for quick response.
I have tried the RadaeePDFManager.Show() method, but that creates a new activity.
My requirement is to access the reader's View in order to display it within a fragment view.
I have also tried to use the PDFLayoutView class, from which I was able to set as the fragment's View, but the pdf displays as blank white pages.
Xamarin android - missing binding for PDFReader 9 years 2 months ago #12438
Using PDFLayoutView should be the correct way.
Can you share how extactly are you including it, to check why you see blank pages?
Xamarin android - missing binding for PDFReader 9 years 2 months ago #12439
  • petcha
In the fragment's OnResume method I open the file from internal storage with PDFFileStream.
the variables for is_open, size, result_open, all indicate that the file was successfully loaded.
public override View OnCreateView(LayoutInflater inflater, ViewGroup container, Bundle savedInstanceState)
    pdfLayoutView = new PDFLayoutView(Context);
    return pdfLayoutView;
public override void OnResume()
    base.OnResume();
    var path = "/data/user/0/com.myproject.android/files/1/Documents/TestDoc.pdf"
    showDocument(path);
public void showDocument(string path)
    Global.Init(Context);
    PDFFileStream fileStream = new PDFFileStream();
    bool is_open = fileStream.Open(path);
    int size = fileStream.Get_size();
    Document pdfDoc = new Document();
    int result_open = pdfDoc.OpenStream(fileStream, "");
    bool result_cache = pdfDoc.SetCache(Global.TmpPath + "/temp.dat");
    pdfLayoutView.PDFOpen(pdfDoc, this);
Xamarin android - missing binding for PDFReader 9 years 1 month ago #12444
We have tried your same code, and the pdf if rendered correctly.
Can you try with different documents? also from sdcard?
