Help using PDFSetNote() 9 years 1 month ago #12496
  • petcha
  • petcha's Avatar Topic Author
I'm trying to use PDFSetNote() on the PDFLayoutView, using the Xamarin library on android.
However when I enable the note functionality by calling the PDFSetNote() function it only adds a note icon to the pdf, without showing any edit controls.
Should I have to implement a custom view/controls to capture the text from the user? If so, could you please provide a sample of how to modify the note annotation manually?
Thank you.
Help using PDFSetNote() 9 years 1 month ago #12497
In the demo project, the edit controls is not shown immediately (it's based on a button click)
The method that shows these controls is PDFEditAnnot in PDFLayoutView, but the note annotation should be selected first (single tapped)
The following user(s) said Thank You: petcha
Help using PDFSetNote() 9 years 1 month ago #12546
  • petcha
Thank you that works on annotations already added.
Is there any way to get a reference to the Annotation once its created. So that as a soon as the page is tapped to place the annotation, the edit controls will show?
Also, would it be possible to use a custom layout for the annotation edit controls?
