Cordova - search and annotation 8 years 9 months ago #12969
  • webonautics
  • webonautics's Avatar Topic Author
Hi There,
Thank you for your help (via the Support Ticket) with the updated classes we were able to bundle a demo app and open the PDF successful. However the search and annotations icon does not seem to display. Is there any specific triggers, callbacks required to activate/display them? Currently we have not included the iOS SDK. Do we need to include it as well?
Regards,
Lathesh
Cordova - search and annotation 8 years 9 months ago #12971
did you include also resources folder? It includes also reader icons.
To add the plugin correctly, I suggest to import it with the command from terminal:
cordova plugin add https://github.com/gearit/RadaeePDF-Cordova.git
You should also call activateLicense method with a valid license.
You can find demo licenses info here:
Android: www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=4
iOS: www.radaeepdf.com/support/knowledge-base?view=kb&kbartid=8
Last edit: by emanuele.
