PDFPageView for a Xamarin Custom Renderer 8 years 9 months ago #12983
  • jsk
  • jsk's Avatar Topic Author
I tried to develop a custom renderer for Android for the class Com.Radaee.View.PDFPageView in Xamarin.
I tried to open a PDF Document via a PDFStream.
I can still successfully open the stream, but opening the document fails.
using(Com.Radaee.Pdf.Document oDoc = new Com.Radaee.Pdf.Document())
using(PDFFileStream oStream = new PDFFileStream())
	oStream.Open(m_strPdfUri);
	oDoc.OpenStream(oStream, null);
Error:
java.lang.UnsatisfiedLinkError:
No implementation found for long com.radaee.pdf.Document.openStream(com.radaee.pdf.Document$PDFStream, java.lang.String)
Does that even have a chance of working?
PDFPageView for a Xamarin Custom Renderer 8 years 9 months ago #12990
  • jsk
Can Radaee PDF be used in Xamarin Forms at all?
To integrate this into Forms, for example, you would need a view derivation that can be encapsulated in a custom renderer.
Is this planned or does it already exist?
PDFPageView for a Xamarin Custom Renderer 8 years 9 months ago #12992
Make sure to call
Global.Init(this);
before opening
Currently any customization needs to be done in the native Android, iOS projects.
Yes, It's planned to provide a view that can be encapsulated in a custom renderer, but for more information you need to contact This email address is being protected from spambots. You need JavaScript enabled to view it.
PDFPageView for a Xamarin Custom Renderer 8 years 9 months ago #13043
  • jsk
For Android I found PDFLayoutView that perfectly meets my requirements to use it in a custom renderer.
Is there anything comparable in the iOS part?
PDFPageView for a Xamarin Custom Renderer 8 years 9 months ago #13045
for more information about Xamarin module customization on iOS, I suggest to open a ticket addressed to Sales and licensing department on our ticket area: www.radaeepdf.com/support/tickets
