Disabling Print feature in PDFViewer 8 years 6 months ago #13342
  • gongtom
I have a question about the PDFViewer in iOS and Android for Xamarin. Is it possible to disable the print feature in both versions? And in general: Is it possible to customize the Viewer in addition to the functions provided? I don't need to know, just of its possible. The rest can be up to the paid technical support, as soon as I buy it with my licenses. B)
gongtom.
Disabling Print feature in PDFViewer 8 years 6 months ago #13344
Yes, it's possible.
Based on the level of the customization, you can achieve it either by customizing the plugin or the java/objective c sources included in the plugin.
The following user(s) said Thank You: gongtom
