Managed Tap on CheckBox 8 years 2 months ago #13781
  • mfranc28
  • mfranc28's Avatar Topic Author
I'd like to know how I can managed tap on checkbox.
I open my PDF with OpenStream, I can edit field type but when I tap on a CheckBox nothing happen.
Managed Tap on CheckBox 8 years 2 months ago #13783
Checkbox/radio buttons are managed on the single tap event, it gets recognized and handled using the following code:
int check = annot.CheckStatus;
            if(doc.CanSave() && check >= 0)
                switch (check)
                    case 0:
                        annot.SetCheckValue(true);
                        break;
                    case 1:
                        annot.SetCheckValue(false);
                        break;
                    case 2:
                    case 3:
                        annot.SetRadio();
                        break;
                mView.RefreshCurrentPage();
                mView.PDFEndAnnot();
If you still have issues with the check boxes, can you please send us the pdf?
The following user(s) said Thank You: mfranc28
