Plugins fails with double click in a link 7 years 8 months ago #14197
  • gcorrea
  • gcorrea's Avatar Topic Author
I've tested the RadaeePDF plugin (I've own premium license) embebbed into an own application. The links works when I clicked and fire the play icon; however if i've double click in a link by error, the link fire, but the toolbar links not change and its only works the play icon. In this situation, I can't close the viewer and I've to kill the app.
Is a bug? Thanks!
Plugins fails with double click in a link 7 years 8 months ago #14198
  • gcorrea
The plugin is used in a iOS APP (under Cordova) developed in Objective-C
Plugins fails with double click in a link 7 years 8 months ago #14199
we fixed this behavior, now you can update the plugin.
Thank you for your report
Plugins fails with double click in a link 7 years 8 months ago #14202
  • gcorrea
Works fine! Thanks!!
