Static library for Xamarin 7 years 8 months ago #14217
  • анд1.5
  • анд1.5's Avatar Topic Author
Hi!
I'm already customized IOS and Android demo projects and now i need to create static library to implement their in Xamarin project and i stuck in this step.
Is there any tutorial?
What is the easy way to do it?
I hope for your help. Thanks!
Static library for Xamarin 7 years 8 months ago #14221
to create a customized iOS and Android Xamarin module, you should update the modules downloading the latest versions.
For iOS you can edit the RadaeeLib project (located in ios/iOS/RadaeeLib) and use the MakeFile (call command "make" from Terminal) to create the new library and replace the existing one (located in ios/RDPDFViewXamarin/RDPDFViewXamarin/libRadaeeLibSDK.a).
For Android you can edit the latest Android Studio demo project (now it's the version 3.50), then build it and copy the aar file (located in PDFSample/ViewLib/build/outputs/aar/ViewLib-release.aar) and replace the current one (located in Xamarin module: android/RadaeePDF-Xamarin/Jars/ViewLib.aar)
The following user(s) said Thank You: анд1.5
